Changing angle on blades
APOSTOLISZEV
Message 1 of 14
APOSTOLISZEV
Any ideas on how i can design blades, on a pipe lets say, so i can change the angle of them easily and fits with the pipe after that change.
Beacuse when i try to rotate them by the command "move" they don't fit to the pipe.
Thank you,
Apostolis Zevgaras
Replies (13)
Message 2 of 14
TheCADWhisperer
Move is almost never the correct move (pun intended).
Message 3 of 14
APOSTOLISZEV
Ok thanks let's say we have this simply case.
Message 4 of 14
TheCADWhisperer
I would have made the coils dependent on d1.
Sketch 5 is not fully constrained?
If I run a Compute All (Ctrl b or Cmd B) there is an error...
Sketch6 is a duplicate of Sketch1?
I don't understand why you did the two Moves?
I don't understand what the original problem description was?
Message 5 of 14
TheCADWhisperer
@APOSTOLISZEV wrote:
Because when i try to rotate them by the command "move" they don't fit to the pipe.
Attach a file in this failed state.
Message 6 of 14
APOSTOLISZEV
Imagine that water flows and i want to find the optimum angle for my blades. To accompish best efficiency.
So i want to change them and see which is a "good" angle. I am going to use theory of triagnle velocity, but i want to see changes in fusion.
By the way thank you a lot for your interest.
Message 7 of 14
TheCADWhisperer
Attach file that didn't work as expected.
Message 8 of 14
APOSTOLISZEV
I want in this geometry, to rotate, to turn the blades.
I want to find a way to do this easily. I dont want to have to fix this from the beggining.
Message 9 of 14
TheCADWhisperer
I don't want to have to fix this from the beginning.
Show me in a picture exactly what is wrong (I think I understand - but if I do understand the issue, you have not shown it yet).
You don't want to fix it???
I was going to recreate it myself from scratch the way I would do it.
If this is too much work for you to start over - I have other work that I need to get done.
Message 10 of 14
APOSTOLISZEV
No i mean that i don't want every time that i want to chage my angle to fix a pipe from the beggining.
This is what is happening when i want to change angle
Message 11 of 14
APOSTOLISZEV
Those blades had different angle. For the second blade i start over my pipe construction. My point is from the first consruction to change the angle of blades and take notes every time i change them. Not to start over the construction every time i want an different angle.
Thank you
Message 12 of 14
TheCADWhisperer
It would have been best if you showed this image of the problem in the original problem description.
Examine the Attached files.
The height of the twist is controlled from the Height parameter variable.
Angle of twist.
Number_of_fins variable...
Parametric table.  Edit Expression as desired.
Let me know if you have any trouble - perhaps I will make a video on my process...
Message 13 of 14
APOSTOLISZEV
I see
Thanks a lot
Message 14 of 14
APOSTOLISZEV
Hello again!!
I want to ask you sth.
Have you any idea on how can we measure the slope of the blades, on the attached file you send me?
Thank you,
