Change Z axis to come out of the top of my rotation cube
Inspections_JCH
Message 1 of 9
Inspections_JCH
I would like to change the Z axis to come out the the grid when i am in top view. My model is properly oriented to its Z axis, so I want to view it in that same orientation while I work on it. The setting in my preferences is Z up.
Replies (8)
Message 2 of 9
shahriarsifat1802164
Go to settings >> design >> unselect Autolook up sketch.
Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Message 3 of 9
When you select the top plane you are already in the x-z place.
RUET
Thank you.
Message 4 of 9
Now checkmark or hit the origin eye now see what happens.
RUET
Thank you.
Message 5 of 9
RUET
Thank you.
Message 6 of 9
RUET
Thank you.
Message 7 of 9
If you found your required information, please give them as solutions.
Thank you.
RUET
Thank you.
Message 8 of 9
TheCADWhisperer
I have no idea what @shahriarsifat1802164  is referring to???
Click on the Front view of the cube.
Right click on the Front view of the cube and set to Top.
You can set this as default in your Preferences for all future work.
Message 9 of 9
laughingcreek
There is also this setting in preferences, which is the way most machinist like to have the orientation-
