Change rendering orientation/lighting
yoshimitsuspeed
Advisor Advisor
yoshimitsuspeed
If the surface you are trying to render is on the bottom it is not illuminated.
Is there a way to change this without needing to rotate the actual part?
https://www.facebook.com/groups/1229995573786339/
JamieGilchrist
Hi Yoshimitsuspeed,
you can change your camera position settings using the view cube to change front or top. This doesn't change the position of the geometry, just the camera position so you can show the surface that you care about. I'll post a video to show you this.
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
JamieGilchrist
Hi yoshimitsuspeed,
here's a quick demo on how to change your view orientatioin.
Change view orientation
let us know if you have any further questions
hope this helps,
Jamie Gilchrist
Phil.E
You got it Jamie, beat me to it.
Here are the helpful pictures I prepared. One thing, the view cube will also determine where the "floor" is, so while you don't have to move the model, it will appear as if you did. All the shadows and reflections respond to where the "floor" is.
Hope this helps!
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
yoshimitsuspeed
Thanks guys
chazz
I came here with the same question as @yoshimitsuspeed.. The behavior or at least the layout is very different now.  See the screenshot below.
below
