Change Dimension Style- hide dimension lines?
I'm drawing a sketch with a lot of dimensioned features and it's gettingcluttered with so many dimension line. How can I change the format of the dimension style so that the double arrow extension lines are hidden?
This is the current look:
I'd like it to look something like this:
Phil.E
What you want is ordinate dimensioning within sketch, and that is not possible today.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Just a suggestion:
You should add a detail view for those smaller dimensions. Adding a detail would separate that area and also allow you to see the dimensions better when making the part.
