Change dimension of circle in a body
Message 1 of 15
I have looked for hours and can't find the answer.  I imported a STEP file and need to change the dimension of a circle in one of the bodies. Seems like it should be simple.   How is this done?
Replies (14)
Message 2 of 15
wersy
Step files are only limited editable.
If you share your file we can see what is possible.
Message 3 of 15
Cotral.RD2
its difficult to give a precise answer without any references. Generally in Fusion 360 step files can be easily modified by direct modelling method.
Pavan HEMMEGE VENKATAPPA
Fusion 360 Ultimate User
Message 4 of 15
TrippyLighting
Use the press/pull tool.
Do not turn the timeline on.
Message 5 of 15
Thanks for the responses and forgive me for  my ignorance, I'm new to Fusion 360.  I've attached the step file.
I want to change the diameter of the largest bearing pockets.  Thanks for any help.
Message 6 of 15
wersy
Yes, as @TrippyLighting mentioned, select the surface of a hole and use Press/Pull to change the diameter.
@TrippyLightingCan you please explain why to swich off the time line?
Message 7 of 15
TrippyLighting
I did not say to turn int off, I suggested not turning it on 😉
For models that were created by importing a STEP file, by default the timeline is not enabled.
If edits need to be made then the first question should be  whether these changes need to be parametric. Many things can be changed without ever turning on the timeline.
Timeline models are about 3 times bigger data wise than models without a timeline.
Message 8 of 15
wersy
Thank you very much for the explanation.
I suspected a deeper meaning.
By the way, I just found out that "Press Pull" isn't parametric anyway.
Important to know that!
Message 9 of 15
TrippyLighting
Yes, it is 😉
The defaults automatic, which "automatically" choose one of 2 options:
Modify original feature )parametric)
and
New Offset, which puts a new item in the timeline.
Message 10 of 15
wersy
Yes, it is 😉
and
Oh dear, I'm afraid it's about time I had a closer look at the options of all features 😉
Message 11 of 15
OK, so here is the problem I'm running into.  I can use push/pull to change the size of the hole, but what I want to do is change the size of the pocket (highlighted in the picture below).  When I select the face of that pocket and push/pull to the size I want, it changes all the way through the object.
I hope I am making it clear.
Message 12 of 15
TrippyLighting
Can you share the model ?
Message 13 of 15
I shared it in message # 5.  Thanks!
Message 14 of 15
wersy
Look at my post 6.
There I already changed one pocket.
Message 15 of 15
YES!  I get it now.  Thanks everyone so much!
