Change 2 parameters with one click
I would like to know if it is possible in Fusion to change 2 parameters without having to change both of them manually. Example : I have a rectangle sketch of 30*50, and i would like it to change to 50*100 without having to manually change in "change parameters" both of the parameters. I would like to just have to click somewhere and it will do the change automatically. I know i could copy-paste an other file and then change the parameters, but i don't really like the idea.
Thanks in advance
jeff_strater
I'm not aware of any way to do what I think you are trying to do, unless it so happens that your rectangle parameters are related to each other.  That is if you always want your rectangle to be twice as long as it is high, you can make the length dimension be twice the height dimension.  Then, you can adjust the rectangle by just changing the height parameter.
You can always change both in one invocation of the parameters dialog, but you would still have to edit both parameters.
If this is not clear, I can make a video for you.
Jeff Strater
Engineering Director
I understand, no need for a video,
thanks anyway for taking the time to respond !
