Chamfers on components
I use chamfers normally on machined parts like shafts or holes and usually try to use the distance and angle combination.  Normally I would select the distance along the length of the shaft and the angle inwards from the shaft outer diameter such as 2mm x !5deg.  Fusion does not always do this the correct way and often takes the distance from shaft outside going inwards and the angle on the end of the shaft.  There appears to be no way to reverse or flip this in Fusion whereas in other CAD systems the flip option is there in the dialogue box.
Beyondforce
Hi @Anonymous
A screencast will be very helpful!
Ben.
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Pavel_Holecek
this chamfer extension is already logged to IdeaStation portal and you can add your vote - http://forums.autodesk.com/t5/ideastation-request-a-feature-or/being-able-to-switch-distance-directi...
For current version there is a workaround how to create chamfer 2x15deg:
Regards
Pavel Holecek
Autodesk QA team
