Chamfer will not mirror
So I have a symmetrical component that I am modeling for work. I have completed one side that has slots and in those slots are chamfered edges, to make it a tapered slot. I created a midplane and tried to mirror the slots and chamfers all at once. I received an error message saying to try to mirror fewer features. So I mirrored the slots and then tried to mirror the chamfers afterward. Same result, an error message. So, I went ahead and attempted to chamfer the mirrored slots. I used the same dimensional input and same selected edge. Why is it not creating the same chamfered edge?
Please help.
TrippyLighting
patilsm
Hi @Anonymous,
Thanks for your post and Sorry for inconvenience you faced.
As per your comments you facing issue while doing Mirror for chamfer and slot feature and you getting error message.So in this case please try to change the compute option which is available in lower side of Mirror dialog box, where  you can see three option Identical/Adjacent/Optimized .....so try to apply Adjacent/Optimized and check your problems gets resolve or not. Let me know you doesn't help you.(You facing this issue Because we have some limitation for fillet and chamfer mirror).
Sagar
Sagar Patil
Software Engineer
Quality Assurance
Autodesk, Inc.
Thank you,
I ended up making another chamfer using distance distance.
