so you didn't apply any of the advise given in that video. namely, use as few points as possible (you used a gazillion), and fully defining the curve (you don't have angles defined for any of the tangent handles.) what's happened is when you redrew the curves you just happen to get the curvature good enough that you where able to get the chamfer to work by shear luck. you don't actually know why it's working (or why it didn't work before). that means you'll just bump up against this problem again, and you still won't know how to fix it.
fwiw, the suggestion from the video of fully defining the spline handles is a red herring. totally unnecessary. most of us here don't bother for fit point splines. (control point splines are a different story)
using as few points as possible is important though. you'll note on mine that each curve segment just has 2 points (and don't have any dimensions). look at the curvature combs on mine and compare them to you curves, you'll see a dramatic difference. that difference will translate to any solid you produce from it, producing less than ideal surface quality. in the case of an extrude the surface will feel wavey to the touch. if you ever want to do something a bit more complected, like lofting, your troubles will just be compounded.
is you part symmetric? looking at your dimensions you can see what your modeling sure isn't.
