Chamfer in middle of a surface
bdrmachine
bdrmachine
I'm trying to model a group of tiles to 3d print.  As with a lot of tile designs each tear of tiles is offset half the length of the last tear.  How do I cut a .05 inch chamfer on these inside tiles?
g-andresen
please share the file
File  > Export > save as f3d on local device > attach to next post
günther
bdrmachine
g-andresen
That could be solved like this.
However, this method is simpler, whereby you can select the individual edges instead of the faces.
günther
bdrmachine
The 1st method work for me.  Thanks so much.
g-andresen
That sounds good.
Please mark posts that have led to a solution with a check mark as "Accepted Solution".
That will make it easier for future readers.
günther
