One constant frustration with Fusion is the chamfer function seems, very consistently, to be extremely difficult to use on real-world parts. I've used Solidworks for years, and had occasional problems. In most cases, if I want to chamfer all the edges on a part, I simply have to click on one or two faces, and I'm done. But with Fusion, it seems all but the very simplest parts either can't be chamfered at all, or require breaking the operation down into several, sometimes many, separate operations. In a few cases, I simply could NOT get the part chamfered as I wanted at all, even after spending a ridiculous amount of time trying every possible option.
The part below is the latest, and most ridiculous, example. Much of it chamfered just fine, though I had to break it into multiple operations. But on the "back" face, the ONLY way I was able to get it done was to make multiple passes around the back edges, selecting individual segments. On each pass, some segments would chamfer, some would not. So I would de-select the ones that would not, and keep going. On the next pass, SOME of the segments that would not chamfer previously, would. After perhaps 3 passes, all segments were chamfered. WTF?? It obviously COULD chamfer everything, but required me to play Whack-a-Mole to find the correct order in which to select the segments to make it work? That is ridiculous! On a more complex part, that could have taken hours!
Ray L.
