Edit. I noticed the embed screencast doesn't show my keystrokes, here's a link to the screencast page where the keystrokes show.
My suggestion is don't use priatives for anything apart from quick experiments where edits are not needed.
Here's a screencast that shows how to create your part using a couple of sketches and sweeps. Note Chain selection is unchecked in the sweeps and path along profile and the use of 3d sketch. While experimenting on one occasion I had the origin of the second sketch move from the end of the coil, that's why I projected a point rather than use the origin.
I've attached the design. A couple of tips you might want to add to what I've done. First, probably should have created the part in a component from the start. Second, you could use parameters to drive the part. As well as the obvious diameters and twist angle you could also parameterise the offset of the 2 way extrude so it always runs out of the end of the part.
Mark
Mark Hughes
Owner, Hughes Tooling
