Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Card Holder
12 REPLIES 12
Message 1 of 13
532 Views, 12 Replies
Card Holder
Hello.
I would like to have a card holder that is higher in front than the back, to cause a slight slope so the cards will not slide out as easy. I can get the box and 3 walls, but I can not figure out how to slope it properly.
Thanks in advance.
12 REPLIES 12
Message 2 of 13
g-andresen
try it this way:
günther
Message 3 of 13
TheCADWhisperer
Message 4 of 13
Great! I went back and was able to get the angle I needed, 5mm in front, 2mm in back, but I would also like to have the 3 walls be leveled/flat at a height of 20mm. Is that possible?
P.S.
If you look at it from the side, I would like it to be 20mm tall and whatever my length would need to be, 50mm in this case. So from all sides it a rectangle.
Message 5 of 13
TheCADWhisperer
@Anonymous Can you File>Export your *.f3d file to your local drive and then Attach it here to a Reply?
Message 6 of 13
So I would have a 20mm by 50mm with a heigth of 20mm and the inside bottom of the tray 5mm in front and 2mm in back, so the cards will not slide out to easy 😁
Message 7 of 13
TheCADWhisperer
I guess that I don't understand the issue.
It the design done?
Is something like the Attached what you are after?
Message 8 of 13
If you look, there is a slight angle from the bottom to the top. I would like the 3 side walls to be evenly flat.
Message 9 of 13
I need it more like this, but with the angled floor in my previous one, without any bends in the upright walls.
If you look at my first attached file, you can see a slight bend near 5mm.
Message 10 of 13
g-andresen
try:
Screencast
günther
Message 11 of 13
in reply to: g-andresen
Oh my stars! Something that easy?!?🙄😖😞
Message 12 of 13
chrisplyler
Or...you know...bake the sloped floor right into your sketch from the start...
https://knowledge.autodesk.com/community/screencast/c1c34233-247d-4b89-9999-24a390071f99
Message 13 of 13
in reply to: chrisplyler
More than 1 way to skin a cat! Thank you all!
