Car vent model workflow
douglasrohman
Message 1 of 10
douglasrohman
Having a bit of a tough time creating defined curves and creating this car vent in general any help or pointers would be greatly appreciated.
Replies (9)
Message 2 of 10
douglasrohman
Another angle.
Message 3 of 10
TrippyLighting
This shows more of a general approach than a complete solution.
Message 4 of 10
chrisplyler
My first attempt...
Not as fluid as required. I modeled it the easy way though. File is attached...
Message 5 of 10
douglasrohman
This is great, Thanks for the help. I was getting stuck trying to define those curves.. Along with just getting lost in how to get from point a to b with this complex feature.
Message 6 of 10
douglasrohman
Wow, this is perfect! Would love to see your workflow as well. I'm Thinking I could just create a plane, If I get that far and then extrude the profile of the air fins through the part?
@chrisplyler wrote:
My first attempt...
Message 7 of 10
douglasrohman
Whoops, just realized I could go through the timeline..Doh.
Message 8 of 10
chrisplyler
Sure. Assuming you start outside the shell, extrude them through as separate bodies, do some Split Body commands on them using the shell as a tool, Remove the leftover bits that stick out, and finally Combine all into one Body.
Message 9 of 10
douglasrohman
Welp, I think I’m learning. How would I go about stretching the part as a whole along the bias of the curved front face?
Message 10 of 10
chrisplyler
1. I'm fuzzy on the phrase, "...along the bias...."
2. Try to model things to the right size/shape from the beginning.
