I wonder what exactly does "capture position" do in the timeline. Say I moved a component twice, and captured its position twice so I have 2 capture position features in the timeline. Then I went back to edit the first capture position feature and move the component to a different location. Now does the second capture position feature move the component to the same position as before (so the editing the first feature has no effect), or it moves the component a certain offset based on the first capture?
Long story:
I tried to design and 3D print a metered waist level finder for my Bronica SQ-Ai camera: https://a360.co/36gtKQQ. One of the design goals is to have a magnifying glass which can be stored inside of the finder hood and be taken out and attached to the top of the hood when needed. I modeled the magnifier in its top position and then moved it into its storage position and modeled the storage slot referencing its new position. After that I did a bunch of other stuff and moved other components around. Now I want the magnifier to be further away from the wall when it is stored so I went back to edit the captured position, but that messed up the timeline after it (capture position features after it are messed up). What should I do now?
