cant move a arm with different joints
elev.philip.ardvall
Message 1 of 8
elev.philip.ardvall
tried different joints if it was the distance that wouldn't be same that made the problem, but sliding joint didn't fix. Do you know how to fix it?
Replies (7)
Message 2 of 8
TrippyLighting
The model you attached to your post does not match the model in the screencast.
Message 3 of 8
TheCADWhisperer
@elev.philip.ardvall
The sketch in the file that you attached is not fully defined?
Edit: After looking at it more closely, there are even more problems than I initially thought.
Message 4 of 8
elev.philip.ardvall
what sketch do you mean?
Message 5 of 8
TheCADWhisperer
Did you Attach the correct file?
There is one and only one sketch in the file that you attached.
(view in My Videos)
Message 6 of 8
elev.philip.ardvall
sorry selected right,
Message 7 of 8
TheCADWhisperer
Can you File>Export your *.f3d or *.f3z file to your local drive and then Attach it here to a Reply?
Message 8 of 8
TheCADWhisperer
Do you still need help solving this?
