Cant make this letter extrudable with the other letters
xx_jackass_xx
xx_jackass_xx
I cant seem to figure out how to make this F extrudable with the other letters. I have searched and searched any help would be appriciated.
davebYYPCU
The F is not it's own profile.
The boundary hole / overlap is here.
Might help....
xx_jackass_xx
how do i fix this?
jhackney1972
Take a look at the Screencast to show the process of finding and fixing a "Fixed" constrain sketch.  @davebYYPCU has already identified the point that has an issue but this technique can be used on any broken profile sketch.
John Hackney, Retired
davebYYPCU
Edit Sketch
Unfix All
Make a window select over that intersection and Delete.
Make a second window select over the same intersection, select Coincident.
Might help....
xx_jackass_xx
THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU!!!! i didnt just want told the answer i wanted to know how to do it!!! this is perfect thank you so much
