Cant able to update my fusion
2021-06-12 16:44:00,573 - MainProcess(12072) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\USER\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2021-06-12 16:44:00,630 - MainProcess(12072) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2021-06-12 16:44:00,630 - MainProcess(12072) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2021-06-12 16:44:00,631 - MainProcess(12072) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001AF46612688> #
2021-06-12 16:44:00,631 - MainProcess(12072) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2021-06-12 16:44:00,631 - MainProcess(12072) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2021-06-12 16:44:00,631 - MainProcess(12072) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\USER\AppData\Local\Autodesk\webdeploy\production\2a0e6841a65bd64ca8392d2c15739f5b191739b9\resources\buildinfo.json
2021-06-12 16:44:00,962 - MainProcess(12072) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2021-06-12 16:44:00,962 - MainProcess(12072) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20210325140500
2021-06-12 16:44:00,962 - MainProcess(12072) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2021-06-12 16:44:01,010 - MainProcess(12072) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\USER\AppData\Local\Autodesk\webdeploy\production\2a0e6841a65bd64ca8392d2c15739f5b191739b9\resources
2021-06-12 16:44:01,068 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer - INFO :: New logging level: 20
2021-06-12 16:44:01,068 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: Start to run process: Update
2021-06-12 16:44:01,630 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\USER\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2021-06-12 16:44:01,631 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2021-06-12 16:44:01,632 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2021-06-12 16:44:13,500 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2021-06-12 16:44:13,501 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2021-06-12 16:44:13,501 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2021-06-12 16:44:13,713 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2021-06-12 16:44:13,714 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2021-06-12 16:44:13,714 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2021-06-12 16:44:13,714 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2021-06-12 16:44:13,714 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2021-06-12 16:44:13,714 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2021-06-12 16:44:13,947 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 23.203.34.104
2021-06-12 16:44:14,023 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2021-06-12 16:44:14,028 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: S_I: MjMuMjAzLjM0LjEwNA==
2021-06-12 16:44:14,028 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xMzcuMQ==
2021-06-12 16:44:14,028 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2021-06-12 16:44:14,029 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2021-06-12 16:44:14,328 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Update status: full
2021-06-12 16:44:14,328 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Latest streamer version required updated to 20210331110700
2021-06-12 16:44:14,328 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Upgrade streamer...
2021-06-12 16:44:14,329 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.self_deploy - INFO :: Streamer folder "C:\Users\USER\AppData\Local\Autodesk\webdeploy\meta\streamer\20210331110700" is found
2021-06-12 16:44:14,521 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.self_deploy - INFO :: Find the latest streamer executable "C:\Users\USER\AppData\Local\Autodesk\webdeploy\meta\streamer\20210331110700\streamer.exe"
2021-06-12 16:44:14,521 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.self_deploy - WARNING :: Already installed the latest streamer, do not need to update the streamer
2021-06-12 16:44:14,522 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.self_deploy - INFO :: Streamer folder "C:\Users\USER\AppData\Local\Autodesk\webdeploy\meta\streamer\20210331110700" is found
2021-06-12 16:44:14,522 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.self_deploy - INFO :: Find the latest streamer executable "C:\Users\USER\AppData\Local\Autodesk\webdeploy\meta\streamer\20210331110700\streamer.exe"
2021-06-12 16:44:14,525 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.self_deploy - INFO :: Create shortcut file: C:\Users\USER\AppData\Local\Autodesk\webdeploy\meta\streamer\streamer.bat
2021-06-12 16:44:14,526 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2021-06-12 16:44:14,526 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2021-06-12 16:44:14,548 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2021-06-12 16:44:14,549 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2021-06-12 16:44:14,549 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2021-06-12 16:44:14,791 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Update status: full
2021-06-12 16:44:14,793 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Searching the database for installed apps to update
2021-06-12 16:44:14,793 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Currently installed version for app 73e72ada57b7480280f7a6f4a289729f is 2.0.10027(20210402041906)
2021-06-12 16:44:14,793 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Try to fetch full update manifest file.
2021-06-12 16:44:14,794 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2021-06-12 16:44:14,794 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2021-06-12 16:44:14,812 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2021-06-12 16:44:14,812 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2021-06-12 16:44:14,812 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2021-06-12 16:44:15,068 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Update status: full
2021-06-12 16:44:15,068 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: App(73e72ada57b7480280f7a6f4a289729f) needs to upgrade from 2.0.10027(20210402041906) to 2.0.10253(20210605180912)
2021-06-12 16:44:15,069 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: The sink is <neutronSupport._NeutronUpdateProcessProgressSink object at 0x000001AF2EE52508>
2021-06-12 16:44:15,069 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: The apps should be updated are [<adsk.dls.streamer.manifests.Application object at 0x000001AF33EED5C8>]
2021-06-12 16:44:15,069 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2021-06-12 16:44:15,070 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Delegating process to C:\Users\USER\AppData\Local\Autodesk\webdeploy\meta\streamer\20210331110700\streamer.exe
2021-06-12 16:44:15,077 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Passing parameters: ['-a', '73e72ada57b7480280f7a6f4a289729f', '-s', 'production', '--conn', 'https://dl.appstreaming.autodesk.com/production/', '-p', 'update', '-d', 'C:\\Users\\USER\\AppData\\Local\\Autodesk\\webdeploy\\production\\6a0c9611291d45bb9226980209917c3d', '--no_cleanup', '--logfile', 'C:\\Users\\USER\\AppData\\Local\\Autodesk\\autodesk.webdeploy.streamer.log', '-v', 'INFO']
2021-06-12 16:44:15,077 - MainProcess(12072) - Dummy-1 - adsk.dls.streamer.windows.platform - INFO :: Full command line: ['C:\\Users\\USER\\AppData\\Local\\Autodesk\\webdeploy\\meta\\streamer\\20210331110700\\streamer.exe', '--headless', '-a', '73e72ada57b7480280f7a6f4a289729f', '-s', 'production', '--conn', 'https://dl.appstreaming.autodesk.com/production/', '-p', 'update', '-d', 'C:\\Users\\USER\\AppData\\Local\\Autodesk\\webdeploy\\production\\6a0c9611291d45bb9226980209917c3d', '--no_cleanup', '--logfile', 'C:\\Users\\USER\\AppData\\Local\\Autodesk\\autodesk.webdeploy.streamer.log', '-v', 'INFO', '--headless_pipes', '11076,10944']
2021-06-12 16:44:28,359 - MainProcess(12808) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\USER\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2021-06-12 16:44:28,361 - MainProcess(12808) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2021-06-12 16:44:28,361 - MainProcess(12808) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2021-06-12 16:44:28,361 - MainProcess(12808) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000020B87AA6808> #
2021-06-12 16:44:28,361 - MainProcess(12808) - MainThread - adsk.dls.streamer.configuration - INFO :: # Screenshot (18).png
piotr.kornafel
Autodesk Support
Autodesk Support
Hello @Anonymous
First, you can try this troubleshooter form to help solve the most common issues for Fusion 360 failed updates.
If this didn't solve your problem try the following steps:
Piotr Kornafel
Global Product Support
 Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
rushabhthakkar_910
  1. https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Err...
  2. https://forums.autodesk.com/t5/fusion-360-support/the-update-failed-to-complete/td-p/8568743
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
