Cannot thicken a faceted surface
sammymoz
sammymoz
Hey guys, I'm making an object and want it to have the low poly effect without converting it to a mesh. I've followed these instructions from a previous forum post: Screen Shot 2022-04-07 at 3.08.32 pm.png
I am now stuck because it's not letting me thicken my surface. They are all yellow and facing the same direction. FiScreen Shot 2022-04-07 at 3.55.47 pm.pngFile is attached.
Thanks in advance.
Accepted solutions (3)
dsouzasujay
Hi @sammymoz,
There are some fix that has to be done for the geometry before thicken
  1. The Surface is not created properly, See below image.
  2.  We can reverse the normal using "Reverse Normal" command
    Invoke the command, Box select all the surfaces, OK
  3. There is duplicate surface, overlapping eachother
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
TrippyLighting
The topology of you T-Spline is not OK.
Error message shall not be ignored.
You have self intersection in the T-Spline that need to be removed.
Then you also have an N-gon in the mesh, which when patched also can create problems.
TrippyLighting
If you fix the above, you can crease all edges and don't need the patch tool.
Then it can also be shelled.
sammymoz
Okay thanks heaps for opening it up and having a look! seems like I just need to start again and do the sculpting carefully!
sammymoz
Wow! This is awesome and a much better workflow. Thank you sir!
TrippyLighting
You can accept one, or more posts as a solution, on the so named button 😉
