Announcements
cannot select rib face
sudiebhagwandin
sudiebhagwandin
Total beginner here, trying maybe more that he should.
I have made some ribs on a body (the upper housing of a diff case)
I want the rib side faces to have a bit of an angle to simulate the casting release angle.
the axis of rotation should be the diagonal on each face.
I think my problem lies in the fact that my ribs were created from a single line (as done in the videos I saw on ribs)
which means there is no face to select?
I'v attached my progress thusfar.
the diff I'm making:
Mark-IV-NACM-133-1
g-andresen
maybe this?
günther
sudiebhagwandin
thanks, but filleting will be done later, after I have set the angle of the face.
all this talk of ribs and fillets is making me hungry!
lee_sanders
Hi @sudiebhagwandin
If I understand you correctly you want to add a draft angle to the rib side faces?
try the draft option from the modify drop-down menu
Lee
Lee Sanders
Technical Consultant
sudiebhagwandin
Yesssss!
Thank you!
it seems I need to select the top of the flange.
Noob thinking error.
lee_sanders
Hi @sudiebhagwandin
it seems I need to select the top of the flange - yes, it used as a reference plane
It seems like you are making very good progress!
thanks
Lee
Lee Sanders
