Cannot Remove a Linked Component
neljoshua
Advisor Advisor
neljoshua
So...
I have an assembly with a number of linked components in it (purchased brackets in this case) and I wanted to remove them from the assembly so that I could build it a different way.  In order to preserve the rest of the model, I thought it best to Remove rather than Delete the components.  So, I right-clicked on the components, but there is no Remove option--only Delete.
In order to remove the components, I first have to break the links.  I thought that I could do this in a group by selecting multiple instances...nope.
One must select each component individually, click Break Link, and wait for Fusion to do it (a few minutes in my case).  This was a waste of my time.
Main question: Why can a linked component not be removed?
Sub-question: Why can one not break the links of multiple components simultaneously?
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
Mike.Grau
Hi @neljoshua,
Thank you for asking about this.
Yes, the remove feature is currently not available through the Browser tree but you can
select the imported Xref in the Timeline, right-click on it and select "Remove".
I agree, it would be a great enhancement to break the link for multiple Xref´s in one shot.
As you can see this in the IDEA post from @TrippyLighting here, you may want to add some come of your ideas as well.
I look forward hearing from you.
neljoshua
@Mike.Grau,
Thanks for the information.  I look forward to both of these things being addressed in the future.
__
mihai.stanimir
This only partially solves the issue, as it doesn't work if you make a pattern out of the Xref and later want to remove an instance (to clean up for printing for example).
TheRealWilliam
Had the same problem... My solution: Create a new empty component, move all the linked items you want to delete into that new component, then remove the component.
trevin_powel
Community Visitor
Community Visitor
Still not fixed 7 year later??
