Cannot move sketch - why?
men8ifr
men8ifr
See below, I have not placed any anchors in the sketch and although most parts are related I cannot move it (the big triangle) , what is stopping it move? I've tried the move command and dragging neither work.
g-andresen
Please share the file.
File > export > save as f3d on local device  > attach it to the next post
günther
shahriarsifat1802164
Please attach your file
Thank you
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
men8ifr
Thanks for the reply, any options to do this without sharing the file? What would be the method to find out why it can't move - the fact it's blue means its not fixed right?
jhackney1972
The reason could be any number of things from sketch constraints, fixed geometry, projected geometry, etc.  Without the model you are expecting the forum users to tell you the reason from a picture, that is not realistic.  Please share your model if you want an answer.
John Hackney, Retired
TheCADWhisperer
@men8ifr wrote:
What would be the method to find out why it can't move...
Locate the unintended projection(s).  I would start with the obvious one first.
@men8ifr wrote:
...any options to do this without sharing the file?
Start over from scratch.
