Cannot Invite (disabled)
krsykes
Message 1 of 10
krsykes
Could anyone advise why the 'Invite' button and the 'Enter email addresses' field are disabled?  I've not needed this function in the past, but I do now.
I did browse the forum for solutions, but the only one that seemed to have the same issue, showed a reply of "This is now sorted", but didn't mention what the solution was.
Replies (9)
Message 2 of 10
TheCADWhisperer
@krsykes
Are you using paid commercial license
or
are you using free personal license?
Message 3 of 10
krsykes
Hi.
I'm using a Paid Licence
Message 4 of 10
jhackney1972
The process I would use is shown in the Animated GIF.  If you have a further problem, attach a video of your process.
John Hackney, Retired
Message 5 of 10
krsykes
On the Data Panel - 'People', I don't see anything like the one shown in the animation.  I get 'Enter email addresses' and 'Invite', but both are disabled.
Message 6 of 10
jhackney1972
If you select the "down caret" do you see "Find Hubs" at the bottom.  I have joined a few teams from invitations so I have a list of these, you probably only have one.  The point I am trying to make is "Are you actually using a Team Environment or are you still on Single User Storage?"  Take a screenshot of you Data Panel after you select the "down caret" beside your name shown in your attached screen capture.
Message 7 of 10
krsykes
I guess I'm in 'Single User Storage'. I only need to connect to one colleague, so do I need to add a 'Team', or can this be done in Single User?
I'm curious as to why the 'Invite' button and 'Enter email addresses' are disabled.
Message 8 of 10
jhackney1972
From your last screen capture, you are using a Team Environment.  I do not know why you do not get the same panels I get when selecting People.  I would suggest you try the second method of inviting members to your Team.  In the video I go over this method, give it a try.
Message 9 of 10
krsykes
Thanks for the video John. I definitely selected the correct folder that I want to share, then I clicked 'Open on the Web', but on the top left hand side, it still shows the Main Folder, whereas yours shows the full directory structure. Something isn't quite right.
Message 10 of 10
jhackney1972
I have sent you an email message via the address you show in your screen capture.
