Cannot export file to Corel
Monodon
Message 1 of 13
Monodon
I am trying to export file with model to Corel. If I export dwg it cannot be opened correctly.
Please help.
Mike
Replies (12)
Message 2 of 13
william.siggee
Hi @Monodon,
Thank you for reaching out!
Is this CorelDRAW you are trying to export to?
Will
William Siggee
Apprentice
Message 3 of 13
william.siggee
Deleting reply duplication
William Siggee
Apprentice
Message 4 of 13
HughesTooling
This is usually because of splines Coral can't read. Does the file import back into Fusion OK?
Mark Hughes
Owner, Hughes Tooling
Message 5 of 13
Warmingup1953
For what purpose? It may be a .dxf is the best way to get 2D design element from a Fusion 360 project to CorelDraw.
Message 6 of 13
Monodon
Yes, I want to export files to Corel Draw 19. After importing dxf to Corel Draw some shape lines disappear.
When I try to view these files in Autodesk Viewer everything is OK.
Message 7 of 13
g-andresen
try:
Spline to polyline
günther
Message 8 of 13
Monodon
Message 9 of 13
Monodon
Message 10 of 13
Monodon
Message 11 of 13
Monodon
Message 12 of 13
Warmingup1953
Can you share one of the problematic .DXF files? And how are you creating the .dxf files out of Fusion 360? Are you right-clicking the Sketch Tree icon and "Save as .dxf"?
Message 13 of 13
g-andresen
Did you take note of the reference in my post # 7?
Splines occasionally cause these problems.
Günther
