cannot add threads to an stl: "there was a problem combining geometry"
this is the first time trying fusion 360. I'm used to simple parametric modelling such as solvespace,
but that can't import an exiting STL.
I need to add threaded holes to an existing model someone else made.  I did:
1. insert->mesh
2. do not capture design history (to get mesh options)
3.  solid->modify->convert mesh to brep
4. create sketch on bottom, add circles, extrude circles to holes
5. create->thread
but it wont let me create the threads
this troubleshoot only suggests doing validate, but that finds no errors
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Una...
TrippyLighting
Fusion 360 and CAD Software in general does not work well, with triangulated meshes (.stl data).
TheCADWhisperer
@Anonymous
See Attached file...
