Can you bend a rectangular tube?
4 REPLIES 4
tomHKD9J
1371 Views, 4 Replies
I am designing a chassis frame rail and it needs to have a bend in it. I tried the pipe command and it doesn't offer a rectangular option, just round and square. I have built a model of the tubing (2x4 steel) but wondering if it can be bent in the drawing to be able to have mandrel bent for production.
4 REPLIES 4
g-andresen
in reply to: tomHKD9J
maybe Sweep helps?
1. create a path (3-D-sketch)
2. create a plane on path
3. sketch the tube profile
4. sweep the profile along the  path
günther
jhackney1972
If you have to bend the actual rectangular tube take a look at this Blog article and video.  Model is attached.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
tomHKD9J
Thank you for the speedy response. That did it!
tomHKD9J
in reply to: g-andresen
I will give this a try as well, I think this will be preferred for the project I am designing if I can get it to work out.
