Can't use dimension with sqrt()
SGoldthwaite
SGoldthwaite
I am drying to enter an expression like sqrt(d1), but Fusion won't accept it.  It will accept regular numbers like sqrt(9).  Why can't I use dimensions variables?
jeff_strater
It's a units thing.  Fusion is very literal regarding units.  If you take the square root of "9 mm", the actual value would be 3 sqrt(mm).  So, you have to do some units gymnastics:  "sqrt (d2/1 mm) * 1mm".
Jeff Strater
Engineering Director
HughesTooling
I think the help is wrong, it states any for the units but a quick test shows it only works with unitless so you need something like sqrt(d1/1mm)
Mark Hughes
Owner, Hughes Tooling
HughesTooling
@jeff_strater thanks for the clarification, still not sure I understand you answer though. Can sqrt() be used without canceling the units?
Mark Hughes
jeff_strater
Hi @HughesTooling,
No, unfortunately, sqrt() is specified to be a "unitless" method.  So, you do have to cancel out the units for it to work.  Just like round(), etc.
Jeff Strater
