Can't shorten bolt imported from solidworks
SGoldthwaite
SGoldthwaite
I imported a Solidworks design for a desktop CNC router.  Most of the bolts didn't import properly and are too long.  I isolated one of them and am trying to use the move tool to make the bolt shorter.  I tried selecting the faces on the end of the bolt and move them toward the head to make the bolt shorter, but it's not working.  Apparently I can only select the whole bolt.  The share link to the design is below and I have the bolt in question isolated.
https://myhub.autodesk360.com/ue298ce311/shares/public/SHabee1QT1a327cf2b7ae29e00bdc08db885
jeff_strater
This design is a parametric (history-based) design.  Move does not work on individual faces in history designs (yet...).  Instead, the tool to use is Press/Pull.
However, the problem is the chamfer face:
This will complicate the operation.  The best thing to do is to delete this face, then use Press/Pull to shorten the bolt, then re-apply the chamfer:
after deleting the face, invoke press/pull, select the face:
make sure the type is set to "new offset", then shorten the bolt:
then, re-apply the chamfer:
Or, of course, you can just cut it off with an extrude, and also re-apply the chamfer.
hope this helps
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
SGoldthwaite
Thanks, I'll give that a try.
