Can't see any treads in this forum
hato54
Message 1 of 15
hato54
What happens, same on my Ipad.
Replies (14)
Message 2 of 15
PhilProcarioJr
@hato54
Look here @brianrepp posted a fix for this.
https://forums.autodesk.com/t5/design-validate-document/fusion-forum-and-hsm-forum-are-blank/td-p/66...
In case you cant see it...
"for the URL of the forums, make certain that you're accessing the secure version, so "https://", not the "http://" version.  The secure one should work consistently, and the non-secure does not appear to be working."
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 3 of 15
hato54
This is the https version!
I have never had this problem before (using Fusion 2 ears)
Message 4 of 15
hato54
Now it works, NICE !
Message 5 of 15
hato54
Still not working!!!!!
If I use https: (normally use this) it's not working but it works using http:
Is this some kind of account problem?
Message 6 of 15
PhilProcarioJr
@hato54
Sorry, I should have looked closer at the image you posted.
I tagged Brian so he can look into it more.
Phil Procario Jr.
Message 7 of 15
hato54
@PhilProcarioJr This is also crazy!
Message 8 of 15
PhilProcarioJr
@hato54
That normally only shows up for expert elites, not sure why your seeing that.... Hopefully when Brian gets into the office and sees this he can look into it.
Phil Procario Jr.
Message 9 of 15
hato54
@PhilProcarioJr But I have this "Fusion 360 Early adopter Ultimate" subscription including support.
Therefore i think it's strange?
Message 10 of 15
PhilProcarioJr
@hato54
I think Ultimate subscription people do have that option...so it could be an account issue.
Phil Procario Jr.
Message 11 of 15
brianrepp
Thanks for the tag @PhilProcarioJr.
@hato54 - does the forum showing up/not showing up appear to be intermittent?  And it shows up even when https?  Would you mind sharing your OS and browser information?  Perhaps via email would be the easiest way to troubleshoot - brian dot repp at autodesk.com
Message 12 of 15
mbostonsprint
I saw this today, several times, on my work location computer, where I have been using F360 fairly consistently most days. Today was maybe a second or third occasion of this behavior in the last 2-3 months. I am working now from my home system, and I can see the threads in the forum, FWIW. I didn't notice any special messages earlier today regarding credentials or permissions. I am also an early adopter/Ultimate subscriber.
Message 13 of 15
davebYYPCU
Had the same problem for 36 hours, as far as I can tell was using the secure setup,
Would display title header but no threads, however was able to open threads in the solved box,
I reported this into the Community feedback yesterday,
Over the same time frame, my system has been showing Autodesk not responding, recover page works, but was almost every new page I was going to in that 36 hours, still happened today
Windows 10, HP Pavilion 23, everything stock standard, ADSL2, with wifi network in the house.
Was the same on Ipad over the same time span.
Have had the not responding on some other web pages, but no where near as consistent as Autodesk, was thinking it may be my end,
Thread is freash but I can view the thread list today,
Anything I can do to help?
Message 14 of 15
brianrepp
@davebYYPCU@mbostonsprint thanks for the info.  Curious, are you still both seeing these behaviors currently, even after clearing of cache and a restart of the browser?
Message 15 of 15
davebYYPCU
I restarted my computer after that last message,
Forum appears to be normal at the moment,
no nothing of caches.
whilst typing this message and my previous PM I get an unprompted, sorry can't perform the requested action message, and I was only typing words no buttons pressed etc.
