can't scale imported .obj files
After importing a .obj file, I am able to use modify commands (such as "move") but scale doesn't seem to be an option. If I convert the imported object into a mesh/T-splice then I can scale it but that only works when the object is fairly simple--if it is a complex object I get a warning that it is not recommended to convert and usually crashes if I try anyway.
Is there a way to simply scale the .obj file without converting it?
Thank you!
--Mark
Replies (12)
innovatenate
Autodesk Support
Autodesk Support
Try using the Scale command on the entire Sketch. See the below video for more detail.
http://autode.sk/1zt5r8u
I hope that helps!
Nathan Chandler
Principal Specialist
It seems that when a .obj is inerted it doesn't become part of the sketch itself...so that as I scale the sketch (as shown in the video tutorial) the .obj file is not impacted.
deyop
The OBJ file and the sketch are independent.  The OBJ insertion will be seen in the browser as a mesh node.
undefined
Subsequently if you are in a Direct Modeling document you can use the scale command to modify the scale by either selecting the node from the browser or direct selection in the workspace.  If you have a Parametric Document you would then create a Base Feature and then insert the OBJ file.  When in the Base Feature mode you will also have access to the Scale command.
Hope this addresses your issue.
Great! Thank you very much
innovatenate
Autodesk Support
Autodesk Support
I apologize for the confusion! I read SVG instead of OBJ! I'm not sure how that happened!  Smiley Embarassed
A tip I can offer that is relavant to this thread 🙂  .. is regarding the convert command troubles.
You may find that you are able to reduce the density of the mesh with the Reduce command in Autodesk MeshMixer. Steps to reduce the mesh density
  1. Import OBJ file into Autodesk Meshmixer
  2. Use CTRL + A to select all (Command + A for Mac)
  3. Activate the Edit > Reduce command (CTRL + R  or Command + R)
  4. Slide the Percentage bar until the mesh is reuced as desired
  5. When complete, export OBJ file and then insert into Fusion 360
undefinedundefined
In Meshmixer, you can also use the configure Units command available from the Action drop down menu to change the Units or Scale (bounding box size) of the OBJ file.
With fewer triangles in the Mesh, the convert command is more likely to succeed. The convert command requires a bit of memory, so the fewer triangles the better.
Nathan Chandler
Screen Shot 2019-07-26 at 2.49.37 PM.pngThis is what happens when I try to import OBJ models - they don't get added as a node under Bodies, and I cannot scale them, nor can I right-click "Edit" them to get into the Mesh workspace (is there an easier way to get into that workspace?) and work with them from there.
Breaking the Link doesn't work either. Please help! I've never imported a model that didn't need significant scaling. I would love it if I could scale at the same time I import.
steve.hooper
2025 and I have the same issue with an imported .obj. When I import into my slicer it comes in at the correct scale but is 10x larger in all directions in Fusion.
TheCADWhisperer
@steve.hooper
Units.
Attach the obj file too if you still have it.
steve.hooper
TheCADWhisperer,
Thanks for responding.
I'd like to submit it, but it is commercially sensitive and belongs to my customer so I can't share it in a forum.
I decided to make my changes in my slicer by placing primitives, cutting, and joining, but it was long and tedious compared to what it could have been in Fusion.
@steve.hooper wrote:
...but is 10x larger in all directions in Fusion.
this sounds kike a units problem.
how are you inserting the obj?  if you are using "file/open"  then fusion will insert as if the units are in cm.  most obj are designed in mm, so it will import 10x bigger.
if you use "insert/insert mesh"  you will get a dialog allowing you to select the correct units (along with some other useful house keeping options).
steve.hooper
Thank you!
That fixed it. 👍
steve.hooper
Thank you. This makes sense.
I used the upload to a project and then insert into design.
I'll try the Mesh option and report back.
Steve.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
