Message 1 of 13
Can't Push/Pull feature on a circular pattern
08:36 AM
I am trying to learn how to use Fusion 360 by doing the tutorial, but am stuck on trying to use Press Pull on the first tutorial. I have replicated 6 diameter objects and now need to extrude them for 6mm. The tutorial says that I should click select on the Press Pull dialog and click on the first object and then click on the second object, the Extrude Dialog appears and says 2 objects selected. I have managed to select 3 objects, but when I click on the forth object the selected box changes to one object selected. When I select the second object the base diameter turns blue, I don't think that it should do that! (see picture attached)
What am I doing wrong?
