Can't move design to a new project
jamie.q.white
jamie.q.white
I'd like to copy a design to a new project.  The "Change Destination" dialog comes up, but I cannot select any Projects.
I also tried making a copy of the design to its home project and then moving it, still the same error: The "Change Destination" dialog comes up, but I cannot select any Projects.
I also tried copying or moving in A360 but I get a "Action not competed" error.
any thoughts?
-jamie
jamie.q.white
update: Tried opening original design and using "Save As".  Still no luck.
TrippyLighting
Are there any linked components in that design or have there ever been linked component in it that you may later have deleted ?
jamie.q.white
good point.  There were linked files but I add them last.  For the file I am trying to copy, I removed them from the timeline because I just wanted the solid parametric model part of the design so I could start a new project with it. Is there a way to search for hidden linked files in a design? Really, I shouldn't be fighting this. F360 should just copy the linked files along with the master.
Just a note to AD: an error message (in plain English) would be helpful. Non-behavior is really hard to figure out.d
thanks!
-jamie
