Can't make a solid hollow
mpavillard
mpavillard
Hi.
I'm trying to make this solid hollow, but it gives me the following error:
It won't allow any thickness. Is it too complicated of a solid to make it hollow?
Replies (12)
g-andresen
There is now permission to download.
Please share the file this way if you are using a personal license.
File > Export > save as f3d on local drive > attach to post
Günther
mpavillard
Done. Thanks
wersy
What is the reason you want to make it hollow?
If you want to print it hollow you can do it without to shell it.
TrippyLighting
If you look at the canvas in the file the OP shared, you'll see that this is the exterior shell of an advanced joystick that houses many buttons, mechanics, and electronics.
TrippyLighting
Looking at the canvas in the file you shared, I'd say that you cannot create this object with solid modeling techniques. You'll need to develop an understanding of surface-based workflows or even create some or all of the shape with T-Spline modeling.
davebYYPCU
I can get 1mm wall thickness, but fails at 2 and 3mm
You might have to update your Fusion files, (I had to yesterday)
as I have a new icon in my Dialogue box, never seen it before, that calls out internal sharp or curved options, sharp did not work.
Might help....
Warmingup1953
laughingcreek
I agree with @TrippyLighting , you'll need to get into surfacing to capture this form closely to the original.
but as long as we're looking at THIS model...
sometimes when trouble shooting, it's helpful to back up and start trying to shell the body at an early stage.  for instance. after the first extrude it will shell to 3 mm just fine (i selected the whole body here, not a face)
but after the second extrude it won't shell-
this one was pretty easy to trace back to this point in the first sketch (sketch 3).
the spline isn't constrained to be tangent, and crosses over the circle a tiny bit, causing this little face, and unfortunate geometry-
adding a tangent-
fixes the geometry at that spot and allows the body to shell.
this unfortunately breaks some stuff down stream you'll have to fix.   there are likely more places that will cause the shell to fail, but stepping through one at a time and trying to shell after each feature can help narrow done where the problem spots are.
good luck!
Warmingup1953
mpavillard
Thank you all of you very much. I'm just a hobbyist and my Fusion knowledge is very limited. I'm ok with geometrical shapes, but I'm a sucker when it comes to more complex shapes like this one, as you can see. I have seen some videos about surface modeling, but I don't feel I have the skills for that, I already tried and it was a horrible result. What I have now it's pretty close to what I need, doesn't need to be perfect, and I like the approach of making the shape in segments, and hollow them one by one.
I think there's something wrong with the top front part, because I've been able to shell this:
But not this:
I'll see if there's something wrong with those shapes.
mpavillard
If anyone is interested, I managed to make it work, with some (probably unorthodox) techniques. I can make it work with the front part not being shelled.
Attached where I'm at now, in case anyone is curious. This should work for what I'm trying to do.
hfcandrew
Isn't it failing because with thin surfaces in some areas (less than 6mm wide) compounded with the fillets, mathematically shelling (offsetting) 3mm in these thin areas creates self intersections.
Like if you were to design a 2mm thick solid 'popsicle stick', then try to shell it 3mm, there is not enough room internally for this. There is only enough room for a 0.9999mm shelling operation.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
