Can't get rid of the XYZ plane display
Cowski
Cowski
I reloaded a saved project to edit it some more and ran into an issue...
The project loaded fine, but the XYZ Plane display (not sure exactly what it's called) won't hide and it appears it's only on this one saved file that it's doing it to.  Is there a hotkey, or a setting I can check/uncheck?
Thanks!
Below is a screenshot of what I'm talking about.
Cowski
I figured it out!!
Simple.....  Hit the letter   V
or
R-click on "Origin" and click on "Show/Hide" as shown below:
Now I can sleep tonight.
etfrench
Or just click on the lightbulb to toggle visibility on and off Smiley Happy
ETFrench
I'm putting together an assembly drawing and was getting quite frustrated with this problem; when I would show/hide my origin gnomon it would go from already visible to a shade darker. I had to go through all of my linked project files and make sure all of the origins were not visible on every part. Low and behold the origin was toggled on only one of my linked parts and when I turned it off and updated the assembly, the origin finally disappeared! 😅
