Can't export an stl... can I ask someone to convert it for me?
divebomb8KKBX
divebomb8KKBX
Could I get someone to export these as an stl? I'm having no luck and under a time crunch. I'll have time to figure out why I can't after I get this done.
jhackney1972
Files are attached.  You were having difficulty of Proto Drawing 1 since it was three separate bodies.  Not sure why on the other one.
John Hackney, Retired
divebomb8KKBX
I'll use your added note and see if I can make some changes and make it work.
Thank you for the uploads and advice.
