Hey all, I am trying to explode text to create solid bodies to machine. The font is called Ironick-Normal. This text wasn't in Fusion so I downloaded it, converted to an OTF then added it to my fonts, all which worked fine.
I saw a solution this morning using a different program to generate an (I believe) SVG then inserting that. My problem is that about a month ago when I first added the text to Fusion I was able to explode the text and subsequently extrude the lettering, no problems. This morning I went back to this project and wanted to change my scaling and the text itself and now I can't explode the text. As far as I know nothing has changed since I first added the text to Fusion.
With Fusion updating as frequently as it does, is there something that could have happened not allowing me to explode the text now?
Thanks for any help.
