Can't draft beyond certain angle
I am having trouble using the draft tool to do some v-groove carving. Before I even get to the CAM part, I'm having trouble getting the model right in CAD. Depending on which outline I select, there seems to be some kind of maximum angle the draft tool will accept, beyond which it gives an error I don't understand:
The operation could not create a valid result. Try adjusting the values or changing the inputs.
It tells me what I can try, but it doesn't explain why what I entered doesn't work. I also get:
Could not taper surface as requested.
sometimes.
I'm attaching some screenshots showing the draft tool perfectly happy with 29 degrees but error's on 30 degrees. There's nothing special about 30 degrees, other outlines won't accept 1 degree, some accept 45.
In case it's not clear from the screenshots, expanding the draft angle another degree isn't going to run the draft geometry into anything else. That said, there are situations where I'd like to be able to do that too.
Any help would be greatly appreciated. Thanks!
