Announcements
Can't delete sketch points
codefoster
codefoster
Why can't I delete the sketch points you see in this picture? I can select them. I'm sure they're selected because I can long hold and choose "sketch point". They won't delete. When I move, rotate, and translate them it seems like weird things happen.
Replies (15)
NicolasXu
Hi codefoster,
The picture were not attached somehow. Could you check it?
In some situation, a sketch point is not allowed to be deleted, such as, the center point of a circle, an end point of a sketch line, etc. It would be greatly helpful if you can attached the model so we can take a deeper look to figure out if it’s a software problem.
Best Regards,
Nicolas Xu
Sr. SQA Eng.
Fusion 360 Quality Assurance Team
Autodesk, Inc.
codefoster
I simply forgot to attach the image, but you solved it anyway. I have some archs in my sketch and I'm sure now that the sketch points are the centers. That makes sense. Perhaps there should be some way of notifying a person when they attempt to delete one that can't be. Perhaps a simple popup in the lower right corner like other notifications.undefined
NicolasXu
Actually, after selecting such points and accessing Delete command from the toolbar or marking menu, we can see the selection is clean in the Delete dialog, which means the Delete command don’t think such points are valid input.
Maybe we should disable the Delete command if the selection only contains such entities. I will pass your feedback to the development.
Thanks and please keep the feedback coming!
Nicolas Xu
Sr. SQA Eng.
Autodesk, Inc.
How do I remove these pink points?? Picture is attached.
Thank you!
NicolasXu
Hi Shreyansb,
Welcome to the community! The points and curves shown in pink are projected objects. They are used to build the association with other objects out of the current sketch.
When we create sketch objects, we might want to refer to existing vertices, edges, etc. and keep the association. For example, we could create a sketch line starting from the midpoint of a body edge. When the bod edge moves, we might want to have the sketch line updated to the new position.
Since the pink objects are generated based on other existing objects, they cannot be moved by dragging.  We can use “Break Link” to break the association or just delete them. However, the capability of associative update will be lost.
As for the pink points shown in your screenshot, they are the end points of the projected line or the center of the arc, so they can only be deleted together with its parent object.
Here is a screencast to show how the associative update works and what will happen if deleting the projected curves.
Best Regards,
Nicolas Xu
Sr. SQA Eng.
Autodesk, Inc.
Thanks for the response, which was quick !
FInally, will these pink and yellow points appear in the final rendered image?
Thank you
NicolasXu
Hi Shreyansb,
We're happy to assist you for any Fusion related questions.
Sketch objects will be hidden automatically when enabling Ray-Tracing rendering in Render workspace.
undefined
We can also toggle the sketch visibility from the browser anytime, even in Model workspace.
undefined
Best Regards,
Nicolas Xu
Sr. SQA Eng.
Autodesk, Inc.
LogicSpeaks
Greetings,
I don't think I understand why these "stray sketch points" appear and what I need to do to avoid them altogether.  I imported traced "letters" spelling "REFLECT" and have shared the file.  Please see http://a360.co/2gTRcKQ
Should be downloadable. Please see sketch to see what I'm talking about.
I exported the paths from Adobe Illustrator as a DWG and imported it into Fusion 360.  I seem to always have these "stray points" within each sketch and they cause some serious problems during my sketch process.  What can I do to avoid them - what am I doing wrong?  I read the above and I don't know if this is the same kind of issue.
Thank you in advance to whomever!
docara
In relation to feedback to the development team, I find those little sketch 'dities' and points left behind REALLY REALLY REALLY (insert a swear word) annoying!!!!!! Especially when you can't delete them.
Matt
jajaho2
is this still a problem or is there now a way to remove those sketch points?
Thank you.
jajaho2
never mind after further experimenting I managed to delete it.
I'm sorry for the confusion.
gaelanQEVSL
Community Visitor
Community Visitor
Hello
I'm having a problem where I had a projected line, but deleted it and now I have floating projection points into two sketches.pinkdotone.PNG
I believe the second one is causing a loft to profile to fail for some reason? I am trying to select the entire sketch/chain as a profile, but in the loft feature box it will only allow me to select a 2 of 4 segment?!? I have a nearly identical profile in a different sketch that works fine. Maybe this has nothing to do with the pink dot...but help on either count would be much appreciated.pinkdot3.PNG
HOW DID YOU DO IT
wacomalt
This is infuriating. I have no idea why this point is here and I cannot break links on it. It also highlights a line in another HIDDEN sketch when my mouse goes near it? that sketch should have no links to the one I'm on, and even if it did why could I not break the link?
TheCADWhisperer
@wacomalt
This will be the easiest one to solve all day.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
