Can't delete face off a body after a split
msa2187
msa2187
Hi all,
I'm trying to delete the highlighted part of the body here: https://gyazo.com/7a26460144e06f028f73b75412776506
However, when I try to do so, I get the error message: "Error: The operation could not heal the edited region of the model.
Try adjusting the values or changing the input geometry."
Here's a picture from another angle: https://gyazo.com/e2cfe94caea68f5edd277a22a3368c74
Does anyone know what I might be doing wrong?
Also, if anyone could tell me how I might be able to combine the two bodies in the project titled Body and Body (1) that would be great.
Thanks!
Beyondforce
Hi @msa2187
1. In order to combine 2 bodies, use the Combine Tool under the Modify menu. 😉
2. Instead of deleting a Body, choose "Remove". This body might have some connection to other bodies, which is why you get this error.
Please let me know, if you still have problems.
Cheers / Ben
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
msa2187
Thanks @Beyondforce
I've tried both of these things and neither worked. I've attached the file in case you'd like to try for yourself.
Thanks!
Also, I'm not trying to delete a body. I'm trying to delete a single face off a body.
jeff_strater
Hi @msa2187,
You can do this, using the Patch workspace.  The screencast is below.  However, this is not really a good modeling technique (to have this infinitely thin face in a solid body).  So, if you can avoid modeling this way in the first place, it would make your life easier.
The general technique to use here is to go to the Patch workspace, select the two faces one at a time and delete them.  This leaves you with a surface body, which you then need to stitch back into a solid.  Once that is done, you can use Combine to join them together.
Screencast:
Jeff
Jeff Strater
Engineering Director
