Can't delete a body
Can't delete a body
codefoster
Message 1 of 16
Can't delete a body
codefoster
WARNING: I'm very new to this 🙂
I just created a body and a t-spline (a form?). And then tried to click on the body to delete it and can't. I get the error you see below. It's such a simple operation. I'm guessing I could try a bunch of stuff and it would go away, but I'm hoping a proper answer will reveal a concept I'm missing. Thanks.
Replies (15)
Message 2 of 16
jeff_strater
Most likely you are just selecting the faces, not the whole body.  Try selecting the body in the browser:
Then, use Delete.  It should work then.
Thanks for posting
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
Message 3 of 16
Mike.Zhang
Yes, Jeff is right.
You also can change the Selection to only select the Bodies to get you want.
Mike.Zhang
SQA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Message 4 of 16
codefoster
Perfect. Thanks. I was double clicking and it appeared to be selecting the body, but I guess that just selects all faces.
Message 5 of 16
codefoster
Great to know. Thanks!
Message 6 of 16
codefoster
By the way, I've since discovered click and hold which brings up a menu and allows you to explicitly determine what you meant to click on, and you can choose the Parents tab and then Body. Slick.
Message 7 of 16
This isn't working for me. The body just stays there taunting me.
Message 8 of 16
TrippyLighting
This thread is old and Fusion 306 has changed much. Please create a new thread and share your model.
Message 9 of 16
Wouldn't it be better to keep this thread up to date instead of making a
new one?
Message 10 of 16
TrippyLighting
Nope!
Message 11 of 16
johyphenel
As someone who just got brought here by searching for "Can't delete body", I have to say I vastly disagree that starting a new thread was the right thing to do here.
Message 12 of 16
laughingcreek
As someone who frequently answers questions here, I would have to agree with @TrippyLighting .  New posts with fewer responses will get a lot more people to look at your question and improve the chances of getting a decent answer.  Most of us aren't to interested in jumping in the middle of an on going conversation.
Message 13 of 16
I fell into the same trap as everyone else. Can't delete the body, attempt to follow instructions only to work my way to bottom of thread and discover it's out of date. Perhaps you could delete out-of-date advice, because I have to wade through out of date search results to try and find up to date results. Thanks
Message 14 of 16
TrippyLighting
I suggest you start a new thread and post a detailed description of the problem. It is usually very helpful when users share the designs they have a problem with (export as .f3d and attach to post)
Message 15 of 16
mreitz_dmu
Going to add my name to the list of people trying to find a solution and finding this thread.
Message 16 of 16
TrippyLighting
That list should have ZERO entrants:
