Hi folks,
first of all: Hello from a newbie with the hope for help! Please accept my bad English...
I built a tool for my knife smithing shop. Now I constructed the whole thing component by component in Fusion 360 to share with a few friends. I modelled all the parts of the tool in 3D with imported screws, washers and stuff and combined all the components as I did in reality. From all the components I created a drawing for every machined part with measurements and saved the file with 14 drawings. Everything worked so far.
Then I ran an animation to create an exploded view and received a drawing which I saved in the same folder as the other drawings. This worked too.
Now I want to iport the drawing of the exploded view to the file with the other drawings, cause the bleong together and I only want to have a single file with all the drawings. So I turn out to have two files, one with the 3D-modelling and one with all (!) of the drawings. Now I'm stuck.
A right-click allows me to import a new drawing but when I open the folder where I saved the exploded drawing to, the title says, there are no templates and shows an empty file-structure.
What am I doing wrong? Can somebody help me?
Or is there no solution to combine a drawing from an construction with a drawing from an animation.
Thank you in advance!
Freddie
