Can't change extrude distance
SGoldthwaite
SGoldthwaite
I have 3 extrude ops, when I go to edit them, only one has a field where I can change the extrude distance. The other two don't even have the field in the dialag box.
There should be audio in the screencast, but it's not working on my computer for some reason.
I also attached my Fusion360 design file.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @SGoldthwaite,
For some reason it looks like the model lost its original references and got moved somehow. *Before you perform the next step can you please send me your diagnostic log files from the help menu to [email protected]* To fix this, if you go into the Modify menu and select Compute all, you will notice the model moves and that your sketch profile gets regenerated. Here's the weird thing, if you press undo a couple of times you can notice that it moves back to its old spot, as well as the sketch profile becomes unselectable. Anyways, a compute all seems to fix it and the fields are now editable. Hope that helps!
Your question got successfully answered? Then just click on the 'Mark as solution' button.
James Youmatz
General Adoption Manager | Informed Design
SGoldthwaite
That fixed it, thanks!  I sent you the log files.
