Can't break line at single point
hristo.sabev
hristo.sabev
I'm new in Fusion 360 and I'm having trouble braking a line at a single point. Whenever I select the break tool and point it to the the point I want to break the line it also include a point next to it. Not sure what to change. Also I don't see such an issue in forums and google, so I guess I'm doing something **** wrong.
Attached is a screenshot of my issue.
Thanks and regards,
Hristohow to break just at the middle point i.e. the left red crosshow to break just at the middle point i.e. the left red cross
HughesTooling
Can you export the design as an f3d and attach.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
hristo.sabev
I have just reopened the sketch to make the export and now it works. The funny thing is that before I posted the problem/question I did even restart fusion 360 with the hope to reset any run-time problems that might have caused the issue.
Thus the model seems correct now, and I guess it's some internal structure that got corrupted at run-time. Let me check if this happens again.
Thanks and regards,
Hristo
HughesTooling
One thing I noticed in your screenshot, there's a white dot at the end of the line. This indicates it's not joined to the other line so there could be a small gap, either add a coincident constraint or make sure there's a definite overlap.
Mark
Mark Hughes
