can someone check if it's just me?
prefetch
prefetch
i think event simulation might be broken - and it's driving me crazy and i just need to check if it's a "me problem" or if there is something wrong with the fusion 360 simulation cloud right now.
i'm not a new user, and i've used event sim many, many times over the last year or so.
there's at least one other user that is also seeing the same problem as i am, which is that event sim runs, but after it's done the results are that nothing in the sim moves.  no errors or anything, it's just as if nothing has any load/velocity.
could someone just make a quick event simulation of two objects hitting each other and report back if they actually move?  Smiley Happy
henderh
Hi @prefetch,
It's not just you, we've been looking why loads or constraints aren't causing any movement in Event Sim studies.  There isn't a workaround I know of for now other than using studies created before the May update.
We sincerely apologize for the inconvenience, and we'll fix this ASAP.
Best regards,
Hugh Henderson
QA Engineer (Fusion Simulation)
prefetch
thanks.  i thought i was going crazy there.
looks like it's still broken.  hopefully it get's fixed soon!
henderh
Hi @prefetch,
Could you retry the solves now?  The issue should be resolved.
Best regards,
Hugh Henderson
