Can only change a dimension a little at a time
bentwookie
bentwookie
Hi everyone. I've got a sketch here where I'm trying to build a section to revolve. I built it at some random distance from the origin, and now I'd like to move the whole mess out to the radius I require.
If I set a dimension from the origin to that bottom flange, it's fine. If I increase that dimension by a few millimeters, I can walk the whole collection up as far as I'd like.
However, if I specify a larger jump, the constrains fail to solve and I'm told to remove that dimension.
Can anyone spot the problem, or suggest a way I might build this where I don't run into this issue? I could walk it up, millimeter by millimeter, but you just know that will bite me later 🙂
Here's a link to the file. The sketch is HourRing:Sketch2.
http://a360.co/2pPkYa9
Thanks for your advice!
bentwookie
Heh. So I re-did this, but instead of setting the two right-most vertical lines equal to each other with constraints, I defined them via math. That worked. But having done that, the original collection started solving fine with no change. Non deterministic solver voodoo I guess?
jeff_strater
Thanks @bentwookie, that's definitely a bug.  Thanks for sharing the design.  Glad you were able to find a different way to do that, but we will look at the solver bug with that dimension.
Jeff
Jeff Strater
Engineering Director
bentwookie
Glad to help. Do I need to do anything to preserve the version it was occurring in, or do you all have what you need?
