Can not open Fusion, missing file rcge221.dll
Gabrieltaft
Alumni Alumni
Gabrieltaft
I am unable to open Fusio360 on my computer. I get an error message can not open fusion because it can't find file RCGE221.dll
I have restarted the computer.
Uninstalled Fusion360.
Reinstalled fusion360
two times.
And I keep getting the same message.
Help!
kris_berg
Hi @Gabrieltaft
 Sorry you are having this issue.  In order to fix your issue, you will need to do a clean uninstall and then reinstall.  The directions can be found here:
http://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-...
Let me know if this fixes your issue.
Thank you,
Kris Berg
Fusion 360 Development
Kris Berg
Senior Software Architect - Autodesk
Gabrieltaft
Hey Thanks for that message,
I followed your steps but couldn't find the remaining program files listed below. I keep getting the same error message. Can those files be saved somewhere else?
kris_berg
Hi @Gabrieltaft ,
Sorry it has taken me so long to repond.  For some reason I did not get an email when you replied.  The most critical directory to delete is :
C:\Users\<your username>\AppData\Local\Autodesk\webdeploy.  Do you have a directory with that name?  If so, please delete it and then try to re-install.
Thank you,
Kris Berg
Kris Berg
