Can I revolve or sweep and also loft?
So an example of this.
Lets say I have a sketch of half of a circle on the X plane
And then half of an elipse on the Y plane
I want to revolve (or sweep) from the circle to the ellipse, to smoothly blend into the two shapes.
If I use the loft tool, which seems to be my tool, it goes in a straight line from A to B  I've tried using rails and such with the loft tool but can't seem to get it to work, or to find a tutorial showing this sort of odd operation.
g-andresen
Hi Derek,
Is that your goal?
loft + single railloft + single rail
günther
Ah ha, it appears that my problem was putting the rail on the inner edges, on the outer edge it looks like it works!
TrippyLighting
Mybe share your model ?
