Can i make the viewcube larger?
rhetths
Message 1 of 23
rhetths
Can i make the viewcube larger so i don't need to be as precise so i can operate it quicker and so i misclick less?
Replies (22)
Message 2 of 23
jeff_strater
Sorry, there is no way that I am aware of to increase the size of the view cube.
Jeff Strater
Engineering Director
Message 3 of 23
ImDaveM
I would like to have a resizable viewcube as well!
How about right click on view cube and a scale slider appears?
simples!
Message 4 of 23
rushabhthakkar_910
Resizing of ViewCube in Fusion is not Possible currently.
See this Article..
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 5 of 23
ImDaveM
Hi ,
we know that resizing of the VIEW CUBE is not a thing,
BUT we are asking can you add this as a FEATURE REQUEST !
Message 6 of 23
mango.freund
please take a look --- he never use the cube! https://youtu.be/EtMtW8f0RlE
Message 7 of 23
rushabhthakkar_910
How is the Video relevant with OP's Query..?
If the Person/Person's in the Video are not using the Viewcube, how does it solve the purpose of OP to be able to Increase the size of ViewCube...?
Thanks and Regards,
Rushabh Thakkar.
Message 8 of 23
mango.freund
how does it solve his problem of asking me unqualified questions? pay attention to yourself and your problems and please stop bulling.
to @ rhetths 66 do you know the possibilities to create personalized views?
Message 9 of 23
rushabhthakkar_910
He did not ask specifically to you. Forum is an Open Platform. So anyone can Answer. And It is not an Unqualified Question. It's just a User trying to Know something about the Software that he did not find anywhere.
And you cannot say any users Queries as Unqualified. Be it a very basic one too. We are here to Find solutions and help each other. And not bully them or demotivate them by saying this..
So Please don't use such Language on the Forum's ahead.
Thanks and Regards,
Rushabh Thakkar.
Message 10 of 23
rushabhthakkar_910
This is not the way you are supposed to post on the Forums. And how did I Bully..?
Thanks and Regards,
Rushabh Thakkar.
Message 11 of 23
mango.freund
What do you want from me? I have no questions for you -- I also have no solution for your ads --
it must be possible to respond to the question asked from @rhetths .
so please again -- leave me alone -- thank you
Message 12 of 23
rushabhthakkar_910
Firstly, Sorry for Diverting from the Topic.
Secondly, I want that you don't consider any user's queries as Unqualified. Because that's what these forums are.
To post any type of query be it a Simple one or a Tough one. This a Place from where we can get and Expect Answer's from. And not being judged as a Qualified or an Unqualified Question.
Whether you are a Rank 10, or a Rank 13, or a Rank 1 Everyone has some Question and can post it here.
If you feel it is unqualified keep that feeling with you and do not respond the the post that it is Unqualified. It can demotivate some User.
Thanks and Regards,
Rushabh Thakkar.
Message 13 of 23
TheCADWhisperer
1. I don't understand how this response (and the video) is relevant to the OP's question/feature request.
Can you explain? Yes? No?
2. How is this simple question for explanation "bullying"?
Simple answers to 1 and 2 above.
1. How is your response relative to changing the View Cube size?
2. How can simply requesting additional information be considered "bullying"?
Message 14 of 23
ttemporary75
On my 4k monitor i cannot read the text to see if it is TOP, Front... etc.  This means i need to lower the resolution of my monitor to make it large enough to read. As monitors will keep getting higher resolution. I think Fusion should make it so it can be larger. Is it really that hard? All i am asking is to be able to read what face its on, without having to change my resolution when running Fusion.
Message 15 of 23
Drewpan
I think you need to have a look at RULE #0 that is pinned to the top of the Forum.
This is an open forum for all to ask their questions and all to answer. Nobody should be bullying and nobody should
feel they are being bullied. That being said, all users can learn new things from others and so asking questions for
information should be common and nobody should be offended by asking a question about something they don't
understand. There are developers and CAD Gurus that lurk in this forum and most will always offer to help if they
see an issue. Even an issue that a user does not know they have.
Cheers
Andrew
Message 16 of 23
ttemporary75
Who was i bullying? I stated i could not read the text on the cube. As
this is an open question of many many years and is and will continue to
be an issue. Perhaps you could tell me how i go about asking autodesk to
make features available in a case that it is impossible to make right in
my end. To say the feature is unavailable does not address the problem.
Perhaps for someone with young eyes this is not seen as an issue. It is
very much an issue when i cannot tell if i'm looking at top upside down
or not. If you don't like the post then erase it, but the fact is
Autodesk is not dealing with an issue, which it fixes in other Autodesk
programs.
Message 17 of 23
laughingcreek
@ttemporary75 wrote:
Who was i bullying?...
@ttemporary75 - Drew was addressing a different poster-
He probably didn't notice that the post was from several years ago🙄.
Being able to custom configure the view cube, and other things like line colors etc. is in my view a weak point of fusion.  Hopefully if enough people continue to bring it up AD will make it a priority to address.
Message 18 of 23
mango.freund
Don't forget that you are in a construction program. You can form a cube of your size and place it in the center. You can enforce your will through choice, non-choice and transparency.
good luck
Message 19 of 23
laughingcreek
are you suggesting correcting UI issues with geometry creation?  Not sure how to get the functionality of the view cube from geometry.  perhaps you could provide an example?
Message 20 of 23
TheCADWhisperer
In my work I recommend not getting concerned with relative terms (and can therfore be changed) like Top, Front... ect.
I pay attention to only X,Y,Z.
In all of the various CAD programs that I use they use the same standard convention that X is red Y is green and Z is blue axis.
