Can I make a template from a existing drawing?
SalesDDWKZ
SalesDDWKZ
I have a part (gate) that I manufacture for a customer regularly. I have it drawn as a driven sketch, as only two dimensions change.
As I have done a number of these gates I have a system I like for my drawings.
Is there a way to create a template that is a copy of what I have laid out? I don't think I can do it from a New Template, as there are sub levels that are turned on with upper levels turned off.
Thank you,
Nick
jhackney1972
Probably the only method to reuse the existing drawing is to go into the Web Database, archive (save out to your hard drive) the 2D Drawing, which will also bring along the related model as well.  Once you have downloaded the archive, Upload it back to the Cloud folder, using the Fusion 360 Data Panel or the Web Database, and immediately rename the uploaded 2D Drawing and related model.  You can then use the rename model and drawing for your next project.  I you need further information or a Screencast, let me know.
John Hackney, Retired
ClintBrown3D
Hi @SalesDDWKZ
Right now your best workflow is to download a Fusion archive from the drawing and then upload and edit this copy. We are working on 2 projects behind the scenes, which will greatly improve your workflow, and make this seamless.
I'd love to get your thoughts around this. If you're up for it, here is a link to my calendar, please book a session with me, and we can chat on Zoom. I can also show you some of the new tools that are coming soon (note times are in 24:00 format so 03:00 is 3am, 15:00 is 3pm).
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
SalesDDWKZ
This seems like it will work just fine. Now that I have the archived design in my folder, it isn't too much to upload it and modify a couple things.
Thank you,
Nick
SalesDDWKZ
I will take a look and see when I can chat, this would help in a few places for me.
Thank you for the help,
Nick
