Can I create a pin slot joint that moves in x & y
simon.dyer
Message 1 of 26
simon.dyer
You can see in this video how I want the joints to operate.
As I start connecting up the joints I get joint conflict warnings, before I even get to try and make the cam slot motion work.
Been struggling for hours - any help appreciated.
Replies (25)
Message 2 of 26
dieselguy65
watching, as this is very similiar to a movement i have been trying to accomplish over a year now.
Message 3 of 26
Have you tried using contact sets for the x-y slot? I used a similar approach on a barrel cam. It wasn't the most elegant solution but for a visualisation it was sufficient
Message 4 of 26
dieselguy65
Contact sets work, on really simple things. My experience, this isn't
one of them. My assembly is way beyond what contact sets can handle
Message 5 of 26
TrippyLighting
In that scenario, based on my experience, contact sets will fail and start interfering work regular joints.
I've seen to many user designs struggle simply because they enabled a contact set.
In other words, given that contact set are the only thing that could theoretically help in this case this is unlikely going to work in Fusion 360.
We need 5 more joint types to address common problems and have asked for these for years (at least 3).
Message 6 of 26
simon.dyer
@jeff_strater Woulod you care to comment on this?
Message 7 of 26
jeff_strater
This is, unfortunately, a limitation that Fusion has at the moment:  It is lacking any sort of "cam follower" joint/constraint.  There is likely no way to do this in Fusion today, as indicated here.  It's on the list, but not in progress.  Sorry not to have better news...
Jeff
Jeff Strater
Engineering Director
Message 8 of 26
TrippyLighting
@simon.dyer please mark one of the replies as a solution.
Message 9 of 26
chrisplyler
@jeff_strater
Jeff... Buddy... We've been asking for this for a zillion years. It's been "on the list" for almost as long. Hire some more people. Just need a pin-slot type that will follow a path. Make it happen like yesterday.
Message 10 of 26
TrippyLighting
Well ... we need 5 more joint types to make the Fusion 360 joint system really feature complete. They are all in the idea station.  We've not seen any significant improvements or additions to the joint system in the last 2 years and it is so easy to find a joint that can only be completed with a workaround, or as in this case not at all.
I find this particularly disheartening, because the joint system in Fusion 360 is one of those areas where it really shines. It is beautiful in concept and more than any other areas in Fusion 360  it would so deserve to be feature complete.
Message 11 of 26
andy.c
To the moderator:
I totally agree with Trippy Lighting.  The sole goal of any CAD program today is to increase productivity. To have users pend hours or days trying to find a work around is not helping your cause. Please, do something to complete the joint tool kit. The other awesome features in Fusion 360 mean nothing if you cannot build a model to use them. How many users have given up and had to go back to Solidworks just to stay in business because of the lack of functionality in the joint tool set?
Message 12 of 26
chrisplyler
Two. Two users have had to go back to Solidworks just to stay in business specifically because of that.
Message 13 of 26
Swarfmaker
Add another leaver to the list!
Message 14 of 26
chrisplyler
Really? You can't stay in business unless you can make a functional cam follower type joint in your computer model? This limitation prevents you from producing stuff selling it or whatever you do?
Perhaps your business is actually producing accurately jointed assembly models for others?
Message 15 of 26
dieselguy65
didnt prevent me from staying in business
but it did prevent me from getting the business off the ground with fusion360.
the first real project i tried, that would have been for a substantial payout (6 figures)
wasnt possible to make a working model for the customer to see.
i ended up paying someone to create it in solidworks
i still use fusion, because i just cant get my head wrapped around how solidworks is done.
but the fusion stuff i do is just for me, and fun mostly.
theres some simple things, that are very limiting, and a deal killer.
my projects i think are very simple for a good cad software. if i run into limitations this early on, i can see it getting past the hobby stage for me
Message 16 of 26
JDMather
@Swarfmaker  @andy.c
Autodesk Inventor Professional has a comprehensive list of motion joints - in fact, I don't recall ever having a mechanism where the real world Degrees of Freedom weren't covered within the Joint list.
In my experience - the one area of functionality where Inventor is without question a higher level of functionality than SolidWorks is in the area of Dynamic Simulation (Advanced Motion Analysis).
Dynamic Simulation JointsDynamic Simulation Joints
Message 17 of 26
mac_ito
@jeff_strater And today, almost 2 years later, where are you in this subject and these requests? Is it still on the list, but not in progress?
Message 18 of 26
chrisplyler
Chad - the part time, temp agency, Gen Z stoner that Autodesk calls "the development team" - is still messing with text-on-a-path, and probably will be for another year or so. After that, he's supposed to work on allowing a driven dimension to be used as a dynamic, parametric input value for stuff, which will probably take him another year or two. His timeline has him tinkering with the Joints system long after The Apocalypse.
Message 19 of 26
mac_ito
@JDMather Do you know if it's possible that a version of Inventor on Mac OS will ever be developed?
Message 20 of 26
mac_ito
nothing on the fusion360 app store would achieve this result?
I realize that my question is nonsense..
